280 synchro cross-slide.
Pete.
Post by Pete. » Tue 03 Mar , 2009 19:56 pm
Can anyone supply me with a drawing for the cross-slide on the 280 synchro? I want to make a replacement for mine with tee-slots rather than a compound. I have the material but I could do with a drawing to get the dovetail angles & dims etc exactly right.
Pete.
Andy B
Post by Andy B » Wed 04 Mar , 2009 9:11 am
Drawing numbers:
Saddle Arrangement - should be SL100/500 (MVS100/500 and BVS 100/500 for the 280VS machines), and should confirm the numbers below.
Cross-slide (on 280VS manual & electric, so probably also for the Synchro) MVS100/506
Cross-slide Gib strip - ML100/508B (drawing No. may be ML100/508, as the top-slide gib is numbered ML100/508A, possibly on the smae sheet)
Hope this helps.
Post by Denford Admin » Wed 04 Mar , 2009 10:19 am
Have put what I could find in Downloads
eg:
viewtopic.php?t=1982
Andy B
Post by Andy B » Wed 04 Mar , 2009 11:22 am
Oh well, the consistent numbering theory doesn't always work!
I'll check at home to see if I have a copy of MVS 100/506.
Andy (Admin) - did you find any of the SL.... drawings? I seem to recall that I could not easily find them, and only came across them when looking for something else as they were not labelled on the drawer front. There was a pile of large drawings in one drawer that were folded over, not flat. Could be with those.
Post by Denford Admin » Wed 04 Mar , 2009 11:31 am
There are some SL100 SL150 dwgs scattered among all the BVS ones...couldn't find SL100 / 500 though
Pete.
Post by Pete. » Thu 05 Mar , 2009 20:51 pm
Thanks for posting what you did find Admin :)
Andy B
Post by Andy B » Sun 08 Mar , 2009 19:19 pm
I found my paper copy of MVS 100/506 - so it must be in the Denford drawing chests somewhere......
Unfortunately my copy is very poor, so I'll need to go over the lines & dimensions in pencil before it will scan or photograph well enough to be readable. May take a day or 2 before its done.
Andy B
Post by Andy B » Mon 09 Mar , 2009 20:52 pm
First part of drawing added to downloads.
Will add other bits when I get time to ink them up.
Pete.
Post by Pete. » Mon 09 Mar , 2009 20:55 pm
Thanks Andy - appreciate it.
Post by Denford Admin » Tue 10 Mar , 2009 9:49 am
For anyone else reading the thread later, AndyB has kindly added the drawing to the downloads section:
MVS 100/506
viewtopic.php?t=1986
Andy B
Post by Andy B » Wed 11 Mar , 2009 11:06 am
Final 2 views now in the Downloads section.
