Hi there!
I own an older Triac VMC (1990) and use the original Heidenhain DTT.
My wish is to replace the Eurostep Controller with one of the newer Cards and use the Windows based Controll Software.
Is this just a dream or possible?
Enny
Enny
The Triac with the DTT can be upgraded.
The upgrade to Windows software VR MILLING 5 and a USB or RS232 interface can be made. This can be done on site by our engineers.
The upgrade code is UGR 0007
There is however one exception.
If the triac has a toolchanger fitted and it is controlled by a stepper motor then the current VR software will not drive the toolchanger.
If you have a stepper operated auto toolchanger then the machine can be upgraded but you would loose the toolchanger.
If you have an air operated toolchanger then this is still supported.
Please e-mail Sales@denford.co.uk for a quote on the upgrade and provide the machine serial number with the request and we will be able to look up the specification of the machine.
Hi Steve!
I like good News!
Yes, the VMC has an ATC! The Arm Up/Down In/Out will use air pressure. There is a Motor to turn the Taper Holder!
I have read on your Homepage that an upgrade is only for Maschines after 1992!?
Machine Data:
Model: TRIAC VMC
SerialNo.: EO 4026
DespatchDate: Feb 1992
ExportNo.: 4026
Main Motor 1HP 0,75 DC PH
The upgrade is done by the replacing of the Eurostep Contoller Card (and PC and Cables), nothing more to rebuild on the Machine?
Any Ideas how much it would costs to me?
Thx
Enny
I like good News!
Machine Data:
Model: TRIAC VMC
SerialNo.: EO 4026
ExportNo.: 4026
Thx
Enny
Cost is around £1000-£1200 for Euro card and VR Milling 5 software - you will only have to put a hole in the electrical box to get the USB cable to the card.
Even if you have a stepper driven toolchanger, its still possible to customise the 'PLC' on the new controller so that the stepper redirection relay can be energised when needed at toolchange time.
All the software required to change the logic is on the VR Milling 5 CD.
Its up to you how badly you want to bring this machine up to date
Personally I think its very worth-while as the new control vastly improves machining with block look ahead, smooth velocity contouring and high speed block throughput via USB. The latest version of VR milling also has some handy tools to import DXF and PCB gerber files and create offset toolpaths.
BTW, The USB interface will only work on Win2K or XP PC's, but will still support RS232 comms at 57600 baud on Win 95/98.
Hope this helps
Hope this helps
Sounds good, block look ahead, smooth velocity contouring!
There is one thing that i haven't understand the whole time: is the VRM-Soft necessary to use the machine whit the Euro-Card? As far as i understand it, the Euro-Card's contains the complete Machine-Controls and the Program-Disks add the Control like Heidenhain or Fanuc to write and simulate Programs. In this case the use of the older HH-Control would be possible? I use the Machine for my Hobby and wants to hold the cost as small as possible.
How much is it without the Software?
Thx
Enny
Thx
Enny
Excuse my ignorance but what is a DTT?Enny wrote:Hi there!
Enny
