CYCLONE POWER SUPPLY AGAIN.
g-speed
Post by g-speed » Thu 09 Nov , 2006 18:08 pm
Does anyone have a manual and wiring diagram for a Denford cyclone with a seperate power supply (see earlier question) and fanuc control.
Post by Steve » Thu 09 Nov , 2006 18:49 pm
Please can you supply the serial number of the machine and the date supplied?
g-speed
Post by g-speed » Fri 10 Nov , 2006 12:54 pm
serial number CY02020E Year of manufacture 1990
Post by Denford Admin » Mon 13 Nov , 2006 21:17 pm
Have a look at these..... :lol:
(If you don't have anything that opens DWG, then try QuickCAM 2D - the Demo version will import DWG and DXF, but not let you print)
I presume being 1990, that its an OTA control ? These dwgs are a bit later than that, but should be quite close.
cyclone-fanuc-ota-denford-circa-1993.zip
Cyclone Fanuc OTA drawings from around 1993
(717 KiB) Downloaded 1070 times
g-speed
Post by g-speed » Tue 14 Nov , 2006 17:45 pm
The machine is fitted with fanuc 21i-TA control
Post by Denford Admin » Tue 14 Nov , 2006 18:05 pm
If its a 21i, then it can't be a 1990 machine :?
Here are the drawings anyway..
cyclone-fanuc-21i-electrical-drawings.zip
(1.24 MiB) Downloaded 1084 times
g-speed
Post by g-speed » Thu 16 Nov , 2006 0:29 am
Had another look at machine. On the id plate for the lathe it has a serial number for the the electrical system. This being 9023675.
