CYCLONE POWER SUPPLY AGAIN.
Does anyone have a manual and wiring diagram for a Denford cyclone with a seperate power supply (see earlier question) and fanuc control.
Have a look at these.....
(If you don't have anything that opens DWG, then try QuickCAM 2D - the Demo version will import DWG and DXF, but not let you print)
I presume being 1990, that its an OTA control ? These dwgs are a bit later than that, but should be quite close.
- cyclone-fanuc-ota-denford-circa-1993.zip
- Cyclone Fanuc OTA drawings from around 1993
- (717 KiB) Downloaded 1070 times
If its a 21i, then it can't be a 1990 machine
Here are the drawings anyway..
- cyclone-fanuc-21i-electrical-drawings.zip
- (1.24 MiB) Downloaded 1083 times
