I get “Set XXX Link Function” on VR Milling ver 2 or 5
What does it mean ?
Ver Milling Ver 2/5 "Set XXX Link Function" error
- bradders
This message just means that the Machine (Lathe, Miller or Router) controller was not found. The message may not always appear as it depends on your PC comms settings and any other sofware that is using the comm port.
Check that COM port works, either USB or RS232, and the correct cables are plugged in and secure. If all looks OK, try turning the machine and PC off and on again
