QuickCAM PRO v1.30 released 16th January 2025
The tolerances on the waterline milling calculations have been increased further.
The code base has been updated to be specific for Windows 11, so should slightly faster.
The bounding box in the 3D simulation is full rectangular again without the diagonal lines across them.
Sample files are stored in the common program data directory, not a user's individual documents. This meant that if the admin user was installing, all sample files would be in the admin's documents directory and probably unavailable to the other users. The common program directory is available to all. The initial search file directory after installation will default to this common directory.
Check here to download the latest version:
https://www.denfordata.com/downloads/qu ... ov1_30.zip
