Is it possible to switch off triac spindle for engraving?
Hi all,
I have a Denford Triac CNC machine and would like to use it for some CNC drag engraving using a diamond tip point. How do I switch off or disable the spinning spindle during the run? Even with the speed control dial I can't get it to stop completely.
Thanks for your help
Amer
Amer
is it this one ?
viewtopic.php?t=634
find the run/enable input on the drive (84, 85 or 86 by the looks of it)
pull the wire from there,
wire it to one side of switch
put new wire from other side of switch to run/enable input
HTH
viewtopic.php?t=634
HTH
If you look at that post
viewtopic.php?t=634
You should find the spindle drive as shown, in the black box.
The run input is on the bottom left of the drive board with wire numbers 84, 85 or 86 going to it - the board's silk screen should be marked up run or enable or something like that.
viewtopic.php?t=634
