Is it possible to switch off triac spindle for engraving?
amerkarim
Post by amerkarim » Sun 26 Apr , 2009 11:00 am
Hi all,
I have a Denford Triac CNC machine and would like to use it for some CNC drag engraving using a diamond tip point. How do I switch off or disable the spinning spindle during the run? Even with the speed control dial I can't get it to stop completely.
Thanks for your help
Amer
Post by bradders » Mon 27 Apr , 2009 7:27 am
How are you generating your program ?
If it has a M03 ( Spindle Clockwise) then take this out of your program.
amerkarim
Post by amerkarim » Mon 27 Apr , 2009 11:57 am
I am using the VR milling version 5 software.
Is it possible to switch the spindle off using this software?
Amer
Post by bradders » Mon 27 Apr , 2009 13:40 pm
The spindle will only run in a priogram if it is asked to do so, i.e. there is a M03 is in the program.
The spindle will not run until asked to do so in a program or by pressing a button in Control Panel \Jog or inputting M05 in MDI mode
Post by Denford Admin » Mon 27 Apr , 2009 14:45 pm
You could disconnect the enable/run signal to the spindle drive.
If you're going to want to do this frequently, you could wire up a keyswitch / toggle switch in series with the drive enable/run wire.
amerkarim
Post by amerkarim » Mon 27 Apr , 2009 21:56 pm
Thanks for the tips.
I think fitting a spindle drive switch will be the best option, then I can control the spindle seperately and still use the software I am used to
Which is the wire and where is the best place to isolate it?
Amer
Post by Denford Admin » Tue 28 Apr , 2009 9:06 am
is it this one ?
viewtopic.php?t=634
find the run/enable input on the drive (84, 85 or 86 by the looks of it)
pull the wire from there,
wire it to one side of switch
put new wire from other side of switch to run/enable input
HTH
amerkarim
Post by amerkarim » Tue 28 Apr , 2009 10:04 am
It is a 1998 model Denford Triac ATC, UK supplied, serial number E05218.
Where would I find the run enable terminals and what do they look like? Would they be in the black control box or near the spindle head?
Amer
Post by Denford Admin » Tue 28 Apr , 2009 12:17 pm
If you look at that post
viewtopic.php?t=634
You should find the spindle drive as shown, in the black box.
The run input is on the bottom left of the drive board with wire numbers 84, 85 or 86 going to it - the board's silk screen should be marked up run or enable or something like that.
amerkarim
Post by amerkarim » Tue 05 May , 2009 9:46 am
Thats great,
Fitted a switch and now its drag engraving perfectly.
Just got to make myself a sprung tool now.
Thanks again all
Amer
