Hi Guy,s new I,m new to this forum, I have just bought an Orac lathe but the spindle does not turn in manual or in a program. The vfd is a Imo Jaguar Cub, the vfd light is on but when I press the spindle on button on the control panel the fault light comes on.
Can anybody help please, thanks.
Maybe these pics will help with fault finding:
viewtopic.php?t=864
I'd be tempted to start by isloating the rest of the system, and see if I can get the spindle working "manually". ie, by wiring up pushbuttons for the enables and a 9V battery box for the analogue command.
viewtopic.php?t=864
Thanks for the response. The IMO I have is the VC150 but I tried as you suggested with it disconnected from the system and a manual push switch but the fault led still comes on when the switch is pushed and there is no response from the motor. So I suppose the inverter is U/S. If this is the case would it be possible to fit a different inverter as the VC150 seems rather over rated for this situation and is set on its lowest output of 3amps and the motor only draws 2.3amps.
