MillCAM designer asks to open a file when I Create File
Post by Denford Admin » Fri 12 Oct , 2007 16:24 pm
MillCAM designer asks to open a file when I go to Create G code -> Make File.
What does it mean ?
Post by Denford Admin » Fri 12 Oct , 2007 16:26 pm
Even in later versions of MillCAM designer, the dialog box says "Open" at the top, when you try to create a G-Code file.
Just ignore the message and enter the filename you wish to create, then press OK. You should now be presented with the Create G Code dialog, and your file will be created :)
