im using denford triac software v2.4 to download and upload programs to/from the machine (triac atc 1990) - when using G02 or G03 movements - even though the program runs fine on the graphics and syntax is ok on pc - when uploaded onto triac extra lines are placed in the program mostly G54 datum shifts and also Z movements???? any idea why or how to stop this??? cheers....
I don't know anything about the DOS software, so this is only a guess:
The extra lines must be coming from somewhere-
Either its hard coded into the operating software (can't do anything about it)
or,
There is a file somewhere which holds something like a template - telling the software what information to add (possibly for each machine)
Do a search within all the files for things like "G54" and any other things that are being added.
or,
Admin's right - the extra G Codes that the software is putting into the program when you DNC are hard coded and can't be changed
But I think the values might not be and you may be able to alter them
Try edding (or editiing) the following lines in your TRIAC.OPT file...
MOVERANGEZ 200
TOOLCHANGEZ 200
FYI Non-ATC machines have a Z travel of 235mm, whilst ATC version have a Z travel of 200mm and so the "out of limits" moves the s/ware is putting in
If that doesn't work try adding...
MACHINEEXTENTZ 200
Finally, Ind Text Editor is probably the better s/ware to use for upload/download as it sends exactly what it sees, but you say you've had problems getting it working???
Make sure you load te PNC settings in bonth "Configuration" and "Comms" menus - and if that fails let me know what the symptoms are and I'll try to help further
As always - Good Luck
MOVERANGEZ 200
TOOLCHANGEZ 200
MACHINEEXTENTZ 200
i have tried loading both config and cs files in before i start- when i try to send a program to the machine or run using dnc nothing happens- lines are sent but machine does not move- if i select the PNC option it hangs on first line without sending - i think it is waiting for a transmission from machine??
thanks for replys- any advice is gratefully accepted- cheers lads..
if anyone has a working config file for the TRIAC ATC (1990) please send it to me..
managed to get triac software and industrial text editor to work- but they both have the same problem - it will run through the program fine untill i put a M03 - the spindle starts and gets to revs but then nothing - no more movements??? take the m03 out and it works fine?? i have tried a few different progs.... nothing..
( when i stop the industrial text editor after this it displays error 5!)
can a triac atc (1990) be upgraded?? smooth contouring??
That is strange behaviour???
Because the Ind Text Editor just sends what is in the file, I expected this to work without any problems once you'd got he comms sorted out.
If the "Error 5" message is coming back from the triac then it means "move exceeds limits" (I got this info from the MANUALS.ZIP download on the Denford website - Triac SEC37_P111.JPG) but could also mean the Spindle speed is ecxeeding it's limit - try a small speed like 250 rpm and see if that helps. (The error 5 could be generated by the Ind Ed s/ware in which case I guess it just means transmission aborted)
Also, make sure the spindle start is after your toolchange block- this may help.
Re: smooth contouring - no, the Triac can't "easily" be upgraded. Ripping out the entire electrics an replacing with new is the only option
You I think you may be right
The spindle not getting up to speed would certainly give these sypmtoms - but I'm suprised the permissable error is so small. Your speed is less than 2% of programmed speed!
I think there is a potentiometer mounted on the main circuit board in the "Spindle" section. You could try adjusting this to get the speed right - but make sure you make a note of it's present position so if it doesn't solve the problem you can put it back whee it was! (I think it may be a multi-turn pot too, so it's screw adjustment is through a 10:1 worm gear inside the pot)
unfortunately that hasn't helped- is still stops after an m03 - take it out and the program runs through fine- it does however stop at different points- not always directly after an mo3 maybe a line of 2 after. sometimes i get error 1 come up on indust text editor and error 4 sometimes nothing at all and it just hangs???
It sounds a bit like random comms errors which it can't recover from:
Double check your cables and any plugs/sockets in between
Make the RS232 cable run as short as possible and away from any electrical noise - and good quality shielded twisted pair.
(May be that the comms screws up when the spindle starts because of EM radiated noise
Are RTS / CTS connected at both ends ?
Could it be the speed of the PC or the OS your using ? - try an older one or an application which slows the PC
We had lots of random problems with Win2K and RS232 - also with newer PCs and the comms FIFO buffers (try altering the FIFO buffer size in Device manager)
Yep - thats fixed a few weird comms problems in the past - gives the host and client a bit more time to breath - can you try drop the baud rate to say 300 baud ?Try setting "2 stop bits"
RS232 comms is never 100% accurate and the more you can do to reduce faulty bits being sent - (eg improve noise immunity) the better.
Good idea to try dropping the baudrate Mr Admin
But not too easy on the old Triac PNC machines
The baudrate in the Triac is set via the bank of DIP switches on the main PCB, but I can't remember which ones. I think one switch defined if the machine started up in INCH or METRIC mode, 3 or more defined the baudrate and after that I can't remember, but I do think the baudrate switches were all at one end of the bank so you could just try changing some - the actual baudrate is shown on the screen when you enter datalink mode (well probably - some earlier Triacs didn't show this information)
I think the switches are only read at startup so you'll have to switch off between tries
that worked great just neeeded a delay between characters and 2 stop bits- works every time now.. thanks so much for help..
also got my 7"screen working -needed a replacement video card which i got off ebay for £10- lucky!!
drawbar is also working well now i have re-machined a new slot after the old one was chipped and got stuck on the dowel pin....
