Try these demos:
https://www.denfordata.com/downloads/VRMillingSE.zip
https://www.denfordata.com/downloads/VRTurning-Demo.zip
As far as I remember, you can enter a small number of Gcode lines into the CNC editor and simulate it
I just tried it and the software will let me write some lines of code , but it will not let me move any of the axis on my machine. When i click on the "machine" icon it says i need to buy the full version. Is there any way to move the x,y,z without the software, i don't want to spend the money on the software, to then find out the machine is no good. Thanks for the help.
Hi There,
Talk to Denford Inc (See details below) The cost of replacement software will not break the bank for you rich Florida dwellers
and you will have a good machine at the end of the day. We will always help with Technical problems wherever we can. As a starting point what does the 7 segment display on the control board ? a "2" or and "8" are usually good signs.
Good luck with getting them running
Denford Inc.
815 West Liberty Street
Medina,
Ohio 44256
Phone: 1-800-886-9750
Fax: 1-330-725-3297
sales@denford.com
www.denford.com
Denford Inc.
Medina,
Ohio 44256
Fax: 1-330-725-3297
sales@denford.com
www.denford.com
See I don't mind spending the money, but if I spend the money and then the machine needs a board or something like that, than i'm going to have to spend more money. From the research that I have been doing I can rip all the guts out of this machine and replace them with different drivers like the gecko, etc and use the Mach3 software, for right around the same price as your software. See i also have a microlathe that has the VR turing software version 1.3 and it works, so i would like to keep both of the machines unmodified if possible. Thanks
Reply from Denford Inc.
While I cannot provide you with a trial version of the software, I can put you in touch with our educational reseller in FL. Perhaps you can contact them and if they are out in your area, they may be able to do a demo on site for you or if you make arrangements with them, you may be able to bring your machine to their facility for a demo of the software. If it works, you can purchase from them, if not buy them lunch for their time!
www.jaeger.cc
That is the best we can do.
www.jaeger.cc
