TU150E and Triac PC DOS boot disc make procedure
You first need to create a DOS 6.22 boot disc for each machine. From the web site link below
copy the files from FanucMD for Triac.zip to one of the floppies and that should be OK for the Triac.
For the TU150E copy the 4 files, FLSTEP.APP, FLSTEP.EXE, FLSTEP.GRT and FLSTEP.SHP and the FLSTEP.MSG from the TU150E directory from the FLSTEP Software (Cyclone, Generic, Mirac, Novaturn, TU150E). You will also need to add the DRIVERS2.zip files as well.
