hello i have an orac that has at some time been updated with gecko drives and a altivar 11 controler fitted the conversion is a bitt confusing as it was not a total strip out and uses some of the oracs origional wiring i would like some help with geting this machine back in working order many thanks bert
hi ihave got a small taig mill that i purchased that had been converted by previous owner and the only thing i have had to do with it was to set up the steps to give correct cut lenght and basicly i have no experience with cnc machines or cad/cam programs so i can only use it under manual control via mach 3
i have two oracs both dont work
the first orac has a alvitar 11 vdf and a 8 station auto turret fitted
it uses parts of the origional orac power unit and has one gecko drive
and one rs biopolar drive board fitted
the second orac has two gecko drives and uses the origonal power unit to drive the spindle the spindle starts and can be manualy controled to adjust speed
both machines have break out boards fitted
both of these machines still have a lot of the origional orac wiring in them
my aim is to remove as much of the origional wiring to make things simple
it would be nice have skrew cutting
although cnc convertion looks hard it seems to me that there are only a few components that are required and i seem to have all the bitts required
butt lack the know how to wire them up
so feel that it would be better to start a fresh and have a system that i understand and can maintain
so i would like to use the origional stepper motors
and spindle motor with variable speed control via mach3
spindle speed feed back so skrew cutting is posible
use gecko 201 drivers
get the tool turet to work
i know its going to be frustrating as i am a complete novice butt am confident my goal can be achived as it is just knowing were to put the right wires and set up the correct ports and pins
any help will be most welcome
many thanks bert
many thanks bert
Hi Bert
Similarly if you read through the Mach manuals you will see examples of how to get things up and running.
The oracs probably have a lot of the original wiring in them as you can re-use a lot of the original system like I did -
viewtopic.php?t=452&highlight=starturn
You would be better going through your second Orac and working out what everything is and where the wiring goes, basically coming up with a wiring diagram. There are probably original Orac wiring diagrams on the forum. Once you know what you have got you can then finish it off.
Dave
Bert, you don't need CAD/CAM software to use the CNC setup. Forst thing you need to do is understand G-code and M-code - have a look through the Mach3 Manual online, but it really is very easyi have no experience with cnc machines or cad/cam programs so i can only use it under manual control via mach 3
Dave
hi dave
thanks for your help
the guy who had converted the machines mounted the gecko drives on the old slide in circuit boards
he simply cut a line through all the copper rails and soldered in wires from the driver into the relevent slide board locations
if i have got power to the 12 to 48 volt side
and 5 volts at the common conector on the driver
would i be right in thinking all i am looking for is the step and direction signal inputs from pc tower
i assume that this should pass through the break out board as it is form of junction box
on the break out board is parelle port break out board c1
i have looked for wiring diagrams butt have not found one with only one d25 conector
if i was to look in mach 3 ports and pins i take it that is were i would find out the correct pins that will be used at the d 25 conector
is there any way of working out were the step and direct go
if i do not use the break out board and conect the step and direct wires straight into the d25 on the tower will this have any ill effects not as a permanant fixture but just to see if the stepper will move
i have looked in the back of both machines and there are some differencecs but it looks like the basic power supply system is the same
i have looked at your link pics thank you
does the speed sensor in one of the pics work as this would be a job for another time
many thanks for your help i feel more positive that i will be able to get a machine to work
kind regards bert
kind regards bert
Bert
Yup, all you should need is to find the step & dir pins. These will most likely be on pins 2-9.
Removing the breakout out baord is dangerous as if you do maker a wiring mistake - you could kill the PC.
First thing is when you power the Orac up do the motors lock solid. probably the easiest way to test this is to take of the guard on the back of the cross slid and you can see the pullet. It should turn easily with the power off, turn the power on it should be very difficult to turn. That means the steppers are powered up.
Then try connecting the PC and in Mach ports and pins, disable all axis aaprt from the X then try
Step pin 1 Dir Pin 2
Step pin 2 Dir Pin 1
Step pin 2 Dir Pin 3
Step pin 3 Dir Pin 2
etc
After each change try jogging the X axis.
Try that for starters.
Dave
etc
Dave
hi dave
the machine that i have decided to do first has the spindle motor working in manual control
unfortunatly the break out board is not connected at the moment
i have foud a web site for newer c1 boards butt not for the one i have
i did stumble across a picture of the one i have butt forgot to take a note of were it was
back at work for next few days
cheers
bert
cheers
bert
Right, ignore the speed controller and tool changer. Lets make the carriages move first.
Is the PP on the computer an add on or attached to the motherboard? how fast is the computer? how much ram? You sure it's a PP? ie, magenta colour plastic.
You need a PP cable from computer to breakout board (BOB) check that it is straight through - pin 1 goes to pin 1 etc... numbers are in the plastic if you have a microscope.
Numbers of the relevant pin are written by each connector on the BOB.
go to config/ports & pins motor outputs in Mach3 chose a pin number (except 10 - 13 & 15 as they are inputs) for each step and a pin number for each direction output and don't forget to set the port number as 1 for everything. check on the output signals that there is nothing set to use the same pin - that won't work unless it's a different PP but since you only have one PP.....
Check in Mach3 under config/system hotkeys that X++ and X-- is set to 39 and 37.
Now with a multimeter (MM) - if your connections on your BOB don't have LEDs. Put the MM on common and the X direction pin you have set in Mach3 and now press the left arrow and then right arrow on the keyboard, if you have set the pins in Mach3 correctly you will see the reading on the MM go from 0 - 5v when you bash the arrow keys. Shows at least part of the BOB is working
doesn't work well with step as it depends how fast the step is pulsing.
Now read theGecko instructions and connect the step & dir pulse to those connections on the BOB, if you have power going to the geckos and a motor connected the motor should rotate.
Don't forget to record on paper
Up to now we have ignored any settings of acceleration under motor tuning in Mach3. And any current set resistor on the Gecko.
www.la-coterie.com
www.la-coterie.com
triac whizz
the bob i have is the old type as pictured in your orac heads up 2007
except it has had some extra resistos fitted by previous guy
and extra power conectors fitted in space between the power and input conectors and a three leged thing and has bolted an ally heat sink to it and conected it to a gnd conection
i think it is a regulator or a stabaliser
( i must get a book on electronic components )
i hope to start measurements tonight
i take it that by common you mean the any gnd conection on the bob
bert
bert
hi
the prosesor is a amd sempron (tm)2200+ aat/at compatible 261,620 kb ram
tower unit has two pp a magenta on mother board and a blue one on a seperate card
tested pp cable all 25 pins ok on a continuity test
pluged into magenta pp and connected bob led came on butt dull tested voltage at the power terminals showed 2.1 volt dc
went into ports and pins red crossed all except x axis
set x step to pin 4 and dir to pin 5
checked to make sure pins were not in use in other sections
pushed arrow keys pin 4 showed 2 volt constant and 1.8 volt constant when opposite arrow pused again this was with single pushes tried mutiple pulses on arrow no positive reading recorded
on pin 5 i got a reading of 0-1.8 volts on single push no improvment with multiple pulses
decide to test voltage at bob conector on reverse side on soldered d25 pins tested all pins best was 2.7 volts dc
decided to plug bob and pp lead into second pp got 4.5 volt dc best reading
unsure about how to use this port did try in mack3 port 2 but did not work probably because i have to alter tower setings some how having said that maybe i should have set ports and pins to use port 2
i do have another tower unit thinking of loading mack3 into it and trying it a it has not had any cnc programs loaded into it
arm chair and tea time tommorow is another day
bert
bert
the 'puter shouldn't be a problem then, if you get hold of more ram shove it in, Mach does like it apparently (says he running on an 800Mhz +256 ram
Since I can't see mine at present - is there an estop circuit on the BOB as the latest one cos without the link wire it won't work.
? Have you connected 5v to the BOB? although the latest C1 looks different I'm sure there's a lot of features the same https://cnc4pc.com/Tech_Docs/C1R5WG.pdftested voltage at the power terminals showed 2.1 volt dc
the direction pin will (should) show 0volt one way and 5v there about the other way. step pin would give a reading whenever it was moving, i.e, above 0vpushed arrow keys pin 4 showed 2 volt constant and 1.8 volt constant when opposite arrow pused again this was with single pushes tried mutiple pulses on arrow no positive reading recorded
some BOB's will use a lower voltage input, normally 3.5volts I think ..odd PP you have there.decide to test voltage at bob conector on reverse side on soldered d25 pins tested all pins best was 2.7 volts dc
That's better, I presume that this is a slot in card then?decided to plug bob and pp lead into second pp got 4.5 volt dc best reading
It's more involved than that... have a search on the Mach forumunsure about how to use this port did try in mack3 port 2 but did not work probably because i have to alter tower setings some how having said that maybe i should have set ports and pins to use port 2
www.la-coterie.com
www.la-coterie.com
HI
NOT SURE ABOUT E STOP
DID NOT POWER UP THE BOARD WITH AN EXTERNAL SUPPLY
WILL LOOK TO SEE IF I CAN FIND A 5 VOLT SUPPLY
SECOND PP IS MOUNTED ON A SLOT IN CARD
BERT
BERT
that'll stop it working everytimeDID NOT POWER UP THE BOARD WITH AN EXTERNAL SUPPLY
your pc has one - and a 12v oneWILL LOOK TO SEE IF I CAN FIND A 5 VOLT SUPPLY
psst no need to shout (CAPS)
www.la-coterie.com
www.la-coterie.com
.......appoliges for capps
i take it that you are refering to the spare fly leads comming from the pc supply
will open up tonight and have a look with mm
i did have a problem with pc when i turned it on the screen would not display power button kept going from green to red and so i wigled some of boards inside perhaps i stiil have a duff conection this might be reason for low volt readings
regards bert
regards bert
impact maintenance - I love it :-0 especially basil fawlty style...
www.la-coterie.com
www.la-coterie.com
triac whizz
good news
found 12v and 5v on the only remaining two spare leads for some reason pc has two hard drives a floppy drive one cd drive and one dvd drive
powered up bob with 5v and checked port and pin settings, set pin 6 to x axis dir and pin 2 as step now got 0 and 4.89v for dir and got some strange readings for step .002v
looked through settings found that by setting home limit to 30% got better readings
set up z axis dir on pin8 and pin 7 for step and set home limit to 30% with good results
i might have to change pin 6 as it has had an extra resistor fitted
for some reason the previous guy has cut across the copper rails and bridged the gaps with resistors he has done this to pins 3-4-5-6 they are banded brown green red and gold if i have worked it out right they are 15k +- 5%
thanks for your help so far
i feel more confident now
will try to get wife to up add a photo of bob
bert
good news
bert
triac whizz
hi
i was told not to unplug stepper motors when driver power is on
is it both the 24-48v and 5 v that must not be on
will i have to put a switch on the 5 v from tower ps if so do both live and earth have to be switched and will the same apply to the 24-48v
does the step power and dir wires have to be sheilded wire with sheild conected to a spare gnd point
thanks
bert
hi
thanks
bert
triac whizz
hi with your help things are looking good having now got the grips with some basics i got the feeling it was time to connect gecko drive
butt as i was a bitt unsure i decided to have a more indepth look at what was connected and how
previous guy has mounted gecko on slide in board and i have 63 volts at gecko power input then he has mounted extra components on board to reduce voltage to5.05 volts for other power supply
this machine has a cnc4pc bob fitted and i have traced step and dir wires to find pin locations they go through an extra circuit bord that has some resistors fitted also mouted on this board is a +12 volt supply that has been reduced to 9 volts and goes to bob power supply lots of other bitts are connected for auto changer and speed sensor and as bob led will not light up i plan to make a note of were all bitts that i dont need to get axis moving and see if i can get bob to light led and thinking of conecting pc to see if axis will move
or should i transfer wires into bob that i know is working
incedently this machine has one gecko drive and one what i think is an origional 4 phase rs uni polar drive
with so much exitment i hooked out a spare 12v stepper motor from box of bitts and a spare gecko drive and conected all wires and used a 24v supply and conected 5v from bob set up port and pins and got it to move with mack3
having looked at other machine and traced step dir wire back to bob i now realise that the the four resistors is were the steppers were origionaly wired into pins 2-3-4-5
why does it require resistors between step dir wires and bob
look forward to any comments
thanks bert
thanks bert
?? I don't understand what the other volts are for.. do you mean 50.5volts? why reduce???previous guy has mounted gecko on slide in board and i have 63 volts at gecko power input then he has mounted extra components on board to reduce voltage to5.05 volts for other power supply
gecko will eat up to 80 volts easily
f*ck the wires that are there, just run 3 wires to the gecko, 1 for step one for direction and 1 for ground.this machine has a cnc4pc bob fitted and i have traced step and dir wires to find pin locations they go through an extra circuit bord that has some resistors fitted
NOW THERE COULD BE AN ISSUE.... I think that some geckos take the common as 5volts... and perhaps some old BOB's might not accomodate that..... check the documents and look on the BOB there should be a jumper to change beetween the 2, although that means you'd have to use all geckos....
yeah I know it's exciting the first time it works, but can you re-read & split up before you post, as I'm having to do that to understand...with so much exitment ...
dunno it ain't gonna make the machine work is it! Soundslike somebody didn't know what they were doing.
www.la-coterie.com
www.la-coterie.com
