Hi, I have a problem with a Microturn, when I send the machine to home pisition this moves in the opposite direction in both axes, the problem arose due to change PC, as it damages the motherboard of the PC earlier. I installed the software and the surprise is not going home, away from home (goes to the chuck), if I press the home switches, the current position is saved as home but the directions of the axes are inverted. if I press the lefth arrow key the Z-axis moves in the opposite direction marking a negative trend, the same thing happens with X.
A photograph of the machine appears at the address below.
Http://www.denford.ltd.uk/index.php?opt ... &Itemid=29
Its features are:
Model: Microturn
Serial No: 53579
Despatch date :21-Sep-00
Voltage: 110V FLC: 7A 50Hz 1Ph
Control Voltage: 12V
Spindle Motor: 0.5Hp 0.37KW
Electrics Serial No.: OC00222530
Max. RPM: 2800
Nett Weight: 50Kg
Software version: Denford Microturn V2.12 (DOS version)
Early in the program notes:
Denford Fanuc CNC Lathe (MINT) programming (V2.12)
I reviewed the home switches and are in good condition
What could be the cause?
How could I eliminate the mistake?
axis movement in opposite direction in Microturn
Thanks for the idea but it did not work, I had inverted terminals black and orange in both steppers moters, when I send the machine to home, it arrives at the switch but never released (not save the position of home) and sometimes goes to the chuck. Any other idea?
I think that the problem can be the parameters, I understand that they are on file fanucml.opt, but I don’t know each one of them and if they are correct
AUTOERROR 0
DRAGMARKING 0
DISPLAYSIZE 3
NARROWSIMBOX 0
utils_menu_1 Dos Access
utils_go_1 dos
LOWSPINDLE 100
HIGHSPINDLE 3000
HIGHFEED 500
HIGHFEEDZ 500
SLAVE_XDATUMFEED 400
SLAVE_ZDATUMFEED 400
SLAVE_SPINDLEFACTOR 1.2
SLAVE_ACCEL 160
SLAVE_RAMP 5
machineextentx 127
machineextentz 127
moverangex 127
moverangez 127
chuckcentrex 40
billetz 70
slave_manualfastfeed 500
slave_manualfastfeedz 500
mintool 1
maxtool 16
ATC 0
MINT_MFACT 314.96
SLAVE_MMCONVERT 314.96
METRIC 0
AUTOERROR 0
DRAGMARKING 0
DISPLAYSIZE 3
NARROWSIMBOX 0
utils_go_1 dos
LOWSPINDLE 100
HIGHSPINDLE 3000
HIGHFEED 500
HIGHFEEDZ 500
SLAVE_ACCEL 160
SLAVE_RAMP 5
machineextentx 127
machineextentz 127
moverangex 127
moverangez 127
chuckcentrex 40
billetz 70
mintool 1
maxtool 16
ATC 0
MINT_MFACT 314.96
METRIC 0
