Router 2600 pro Re:- Vacuum Pump
After using the router to cut out components, the vacuum pump continiues to run. Can you please confirm how I should stop the pump without damaging the work or the machine.
Thanks.
so thats why you do it like that...
The Vacuum is held on when in auto.
Switch back to manual mode & then turn it off.
