Description of problem:
When homing the X axis I can hear the motor running but the slide does not move.
If you are sure that the stepper motor is engaging, then you certainly have a mechanical problem with the lathe. In your machine manual (I believe it will be in Chapter 7) is a section on Maintenance. Ensure that the lead screws have been properly cleaned and lubricated. Check to see if there is a need for any of the recommended adjustments.
I need to know that if you try to manually turn the lead screw – will the axis move. If it does not move, then the most likely problem will be a brass sleeve in the saddle assembly has worn out and will need to be replaced. If the axis does travel when turned manually, then we will need to investigate the connection between the stepper motor and the lead screw.
There is one more thing to check, under the front edge of the saddle is a set screw that holds the brass sleeve in place for the X Axes lead screw. Ensure that this set screw is tight (but do not over tighten, as the sleeve is brass). Then try jogging again.
You may need to remove the lathe from the mounting bracket to get access to the set screw. If you need help - let me know.
