Cyclone Fanuc OT 1032 Error Drive Transformer Over Heat
I have a Cyclone Fanuc OT and I have just input all the 900 parameters that Denford's provided me with. But when I input parameter 909 bit 6 I get an "Drive Transformer Over Heat". Does this mean that the Drive Transformer is broken ? :evil:
You need to set the 450 diagnostics
453 bit 2 Drive transformer thermal override.
There may be others that need to be set.
cyclone-ota-otc-diagnostics.txt
(5.9 KiB) Downloaded 1647 times
Here is the same text (I couldn't read the above link properly):
Cyclone Fanuc Diagnostics bits...
Code: Select all
Diagnostic settings for Fanuc OT-A/B/C controls
Diagnostic
 450.0	Pratt type chuck fitted(3 sec air blast)
       .1	Leader blind chuck fitted(constant air)
       .2	Double foot switch fitted
       .3	Single foot switch fitted
       .4	Swarf conveyor fitted
       .5	Powered quill fitted
       .6	2nd coolant pump fitted	"B" control[Zeroturn]
       .7	Aux 1 used for FMS
451.0	Baruffaldi RH80 fitted
       .1	0=6st,   1=8st
       .2	Auto door fitted
       .3	Handwheel interupt
       .4	Machine uses external stop
       .5	Collet chuck fitted
       .6	Spindle indexing is by M19 to M24
       .7	Air pressure switch fitted
 452.0	Lube float switch override
       .1	Door switch override
       .2	Door switch is feed hold only
       .3	Program protect key switch override
       .4	Data input is by MINP (special DNC function)
       .5	Lube float switch is open when empty
       .6	Input 2 is used to open the chuck (FMS)
       .7	X axis must reference before Z
 453.0	Diagnostic setup marker
       .1	Internal gripping
       .2	Drive transformer thermal override
       .3	Chuck uses "chuck is open" & "chuck is closed" input
       .4	Tool select switch starts at binary 0
       .5	Open macro window to PLC
       .6	External stop input is open when active
       .7	Auxiliary outputs off with "CYCLE STOP"
 454.0	Door override pushbutton enable
       .1	Door never gives alarm in auto
 455.0	Direct input offset "B" active (probing)
       .1	Chucking enable push button used (blank button)  	["A"CONTROL -spindle motor thermal not fitted]
       .2	Probe cover switch fitted 	                  	["A"CONTROL-X motor thermal not fitted]
       .3	Index only at home with probe fitted 	                 	"A"CONTROL-Z motor thermal not fitted]
       .4	Door override is not latching (key switch fitted)
       .5	Door override does not work in auto mode
       .6	Chucking sensors normally open
       .7	Chucking sensors issue an alarm
 456.0	"A" CONTROL-Sauter toolpost fitted
       .1	Auto toolpost fitted (any type)	"B,C" controls
       .2	Parts catcher is interlocked with door
       .3	External stop=NC reset
       .4	Hydraulic "A"-not fitted		["A"CONTROL-Toe 80 fitted]
       .5	Hydraulic "B"-not fitted
       .6	Beacon on
       .7	M06 not required
 457.0	Chuck open while running
       .1	Duplomatic BSV 120 toolpost fitted	"B,C" control (Senior)
       .2	Duplomatic BD80 toolpost fitted	"B,C" control (Senior)
       .3	TOE 80 fitted	“B,C”  control
       .4	Zero machine override
       .5	Duplomatic BSV100 live tooling fitted	"C "control (Senior) 	[“A “CONTROL spindle drive fault o/ride]
       .6	New parts catcher fitted	"C" control (Senior)	[“A”CONTROL inp2 block delete TU150-P]
       .7	Manual spindle lock	"C" control (Senior)	["A"CONTROL Door alarm override]
 458.0	Door alarm o/ride	“C” control (cyclone)	[“C”CONTROL senior,spindle shot pin]
       .1	Hydraulic chuck fitted	"C" Control(Cyclone)
Have spent this morning working through various errors and settings to get our cyclone back up to how it was but the only problem we are left with is that we seem to have lost the wear offset page(or soft key options to access this).
Could this just be another parameter that needs to be turned on? Have gone all through the various manuals but cant find anything relevant to this.
Your help would be greatly appreciated
I'm pretty sure tool life wear offsets are a 900 parameter option (ie, one that you would pay for)
Have a search on the web, maybe someone has posted these secret parameters somewhere ?
Surely Fanuc wouldn't want to still take your money for a parameter change :?
Try this link it may be of help
https://www.kentechinc.com/tip2.html
FANUC Version 0T :
X Axis = Par # 535
Z Axis = Par # 536
FANUC Version 0M :
X Axis = Par # 535
Y Axis = Par # 536
Z Axis = Par # 537
4th Axis = Par # 538
I don't think he means wear as in ballscrew, backlash wear - he means tool tip offset wear.
Its an easy way to alter tool dimensions, without changing the original sizes, in order to compensate for wearing of the tools as they cut.
Stick a new tool in, and you can just reset the wear offset to 0 and start again.
I did a google search for:
GEOMETRY AND WEAR fanuc 906
and found your answer (I can't possibly publish it here though :wink:)
Re: Cyclone Fanuc OT 1032 Error Drive Transformer Over Heat
My Fanuc OT is compensating tool offsets in "radius" instead of "diameter." I am searching for the parameter or setting that can be changed that will solve my problem. Any new information will be helpful. thanks in advance
king0714 wrote:My Fanuc OT is compensating tool offsets in "radius" instead of "diameter." I am searching for the parameter or setting that can be changed that will solve my problem. Any new information will be helpful. thanks in advance
Sorry, not sure exactly what your problem is ? ?
That would be correct as far as I am aware, TNR setting in your Fanuc 0T control is exactly that, Tool Nose Radius if that is what you are referring to.
If you are referring to making changes to the tool X offsets then those also are a radius value, so if you alter the X value then that is the adjustment in the amount of "depth of cut"
Mr Magoo, Martin, Steve
