Block skip
I have a subprogram that mills a design in my part. It uses variables that I define in my main program. I want to put block skips on all the lines (tool change, positioning, speeds, feeds, sub program call, etc.) related to cutting this design so I can control which parts will receive the design and which will not. However, VR Milling is giving me an error whenever it encounters a "/" on a line that defines a variable. For example:
/ #502=3
It also ignores the block skip on any line calling up a subprogram. For example:
/N100 M98P9002
Am I doing something wrong or is there a way to do this?
I'm confused now - after your previous post, I presumed you had a real Fanuc control - Reading the axis position is not supported in VR Milling :?
Can you let me know what systems and versions you are using ?
Mr Magoo, Martin, Steve
