Triac Fanuc 1008 spindle drive fault.
The drive is a Lynx-8. Only the ON led is lit. Input voltage is240v. The status relay is closed when it's ON. So all looks good.
On switch on, the controller goes no further than the initial display showing 0415 - 10 and PMC 2.20 - E and 'Not ready'.
Pressing the alarms button display the 1008 fault.
As a background, I had a Z axis crash. After switching back on, it started normally and I changed out the broken tool.
Whilst I was messing about with the program on the PC, I noticed that the screen had changed to this fault.
Reset had no effect and after turning off the fault is as above.
Is this fault preventing the full reboot as previous faults have been displayed once booted up?
Is there a parameter that may have been set by the crash as I guess there may have been a transient drive board overload?
Any help would be much appreciated.
Thanks, Dougal.
