Tee slot dimensions
JonHodgson
Tee slot dimensions
Post by JonHodgson » Wed 24 Aug , 2022 17:52 pm
Due to a design error in the spoil board arrangement that someone before me came up with for our 2600, I need to replace it, so I am currently doing the design.
However, since the easiest way to create the new board will be to cut it on the top of the old one (it works well enough for that), I can't actually get at the original aluminium table to measure it accurately.
As far as I can tell it takes M8 tee nuts, and the slots are 40mm centre to centre, with them being places symmetrically in 430mm width of the bed.
Is that correct?
regards
Jon
Re: Tee slot dimensions
Post by Steve » Thu 01 Sep , 2022 15:44 pm
YES
Travel is 400mm in Y and slots are 40mm apart.
