Inspired by Triac Whizz - here's my machine at work.
Not a particulalry exciting video but just a quick view of my starturn at work the other day. For anyone who says these machines are toys then that is 0.01" depth cuts at 17"/min
It has been as far as 0.01" depth cuts at 20"/min(500mm/min!) with HSS tooling. Just got some new tipped tooling (you can see it in the video) so this may go up yet!
https://www.youtube.com/watch?v=h16qI3TUJAQ
Dave
Starturn at work video
- Triac whizz
Spindle seems slow to me
while I was there I found this https://www.youtube.com/watch?v=YG_A6gvOS24
now where can I put one of these
though I reckon the tool change is rather slow
www.la-coterie.com
www.la-coterie.com
- davidimurray
- davidimurray
Hello
Repeated the same test last night in steel (with the spindle speed turned up
). 1" bar to 5/8" bar in just under 2 minutes. You can actually hear the spindle motor slow at the start of the cut then the closed loop control takes over and holds it steady. No video of that one though as I was running for cover - the guard stops the swarf in some directions but not out of the ends!!!
Dave
Dave
- Triac whizz
seems even slower - how long? 4ft?
www.la-coterie.com
www.la-coterie.com
