Connecting a coolant air valve solenoid for a "Fogbuster"
bpmsl
Post by bpmsl » Sun 15 Jan , 2017 20:22 pm
Hi Folks,
Hoping to get confirmation on controlling coolant on my Novaturn.
I'm intending to use a "Fogbuster" style coolant spray when machining aluminium thus eliminating any issues with getting the machine drenched in coolant.
From the schematics I believe from NVT-D5 that TB3 Output number 2 is a switched 0v (core 84) for use with the 24v control card supply (core 61).
I should use core 84 and 61 to drive a 24v din mounted relay as described in NVT-D3.
I can then switch my "Fogbuster" air solenoid from the relay contacts as I see fit.
Any help gratefully received.
Barry M
Re: Connecting a coolant air valve solenoid for a "Fogbuster
Post by Martin » Mon 16 Jan , 2017 13:26 pm
Without looking at the electrical drawings that all seams fine.
Let me know if you have any issues & I will dig out the drawing.
