Microrouter V4 info required
andy_con
Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
Post by andy_con » Mon 25 Apr , 2016 19:34 pm
I'm looking to purchase this machine and was after some info on it. where might I find the correct spec for it? does anyone know what setup it comes with as standard? doesn't seem to be a manual for it on here, anyone got one?
how does tooling/chuck work on a micro router?
andy_con
Starmills with ATC
Re: Microrouter V4 info required
Post by andy_con » Wed 04 May , 2016 15:10 pm
just received the machine
are there the correct wiring diagrams around anywhere?
is this a vacuum pump at the bottom?
Post by Martin » Wed 04 May , 2016 15:48 pm
Looking at the serial plate it left the factory with VRMilling 2.11. (You can update to the latest version 2.32 from https://www.denfordata.com/downloads/VRM ... _32_CD.zip but you would need to have the licence file to run it).
The Manual can be downloaded from, viewtopic.php?f=37&t=3658
andy_con
Starmills with ATC
Post by andy_con » Wed 04 May , 2016 16:25 pm
I don't have a license sadly, but thanks for the info.
is that a vacuum pump under the machine? what sort of vacuum table would work with that pump? do denford supply them?
Post by Martin » Thu 05 May , 2016 8:53 am
Yes it would have been supplied with a Trend Vacuum Bed. We now longer supply the Trend version & now fit vacuum pads to current machines.
andy_con
Starmills with ATC
Post by andy_con » Fri 06 May , 2016 8:41 am
many thanks for the info.
I'm trying to iron out a few issues, are there any schematics for this machine?
when I press the green vacuum pump button on the front nothing happens, is this control by denford control board? or is that switch linked directly to the vacuum pump?
I'm not sure the door switch is working, I looked a bit knackered. why can the switch be screwed to the door? is the switch suppose to the sprung loaded?
Post by Martin » Fri 06 May , 2016 11:57 am
Yes the vacuum pump switch is interlinked through the NextStep card.
download/file.php?id=1901
andy_con
Starmills with ATC
Post by andy_con » Fri 06 May , 2016 14:56 pm
many thanks for that.
I see inside the machine where the vacuum pump port comes out into the work area. inside the hole is a thread, what thread is that or what is designed to screw into that?
andy_con
Starmills with ATC
Post by andy_con » Thu 19 May , 2016 22:49 pm
whats the pitch of the lead screws on a microrouter?
andy_con
Starmills with ATC
Post by andy_con » Fri 20 May , 2016 13:18 pm
gagging for the pitch of the lead screw if anyone can help?
