Problems cutting HIPS
geofftech
Hardware/Software: 2600 pro
Post by geofftech » Fri 05 Feb , 2016 12:29 pm
We are struggling to cut 3mmHIPS. The shavings seems to melt and gets gummed up around the cutting bit eventually becoming useless as it is thick with melted and hardened shavings. The settings are all correct. We have tried several different combinations of feed rate and speed but cant stop the problem. The cutting bit is 2mm. Any suggestions?
TDIPower
Re: Problems cutting HIPS
Post by TDIPower » Sat 06 Feb , 2016 18:18 pm
are you using a single flute cutter? It has been a while since I machined any but remember I got best results with one.
Post by Steve » Mon 08 Feb , 2016 10:31 am
The suggested rate in the VR milling Library is 2300RPM 1500mm/min and a cut depth of 1.5 x the cutter diameter.
Generally if the material is melting the cut feed is not high enough as the cutter is rubbing and causing heat from friction. you could drop the spindle speed or increase the feed as long as you don't put too much load on the cutter a larger cutter might be better.
