Hardware/Software: Triac '87 converted to mach3
Orac '85 converted to mach3
Part needed please
Post by PDodds »
Does anybody have a spare spindle motor pulley for a green triac?
It has a 14mm diameter bore, with a 5mm keyway broached in.
It has 14 splines on it for the timing belt.
It is the one which goes on the output shaft of the motor.
The diameter across the pulley is 42mm.
Maybe Denford carry them on stock still?
Any help in locating one would be greatly appreciated.
Paul
Re: Part needed please
Post by Lone_Ranger »
PDodds wrote:Hi,
Paul
Try these folks, they will be able to sort out the right gear for you to your specs and not too expensive :D
https://www.hpcgears.com/n/products/1.pu ... _belts.php
Rob
Martin, Steve, Mr Magoo
