E-Stop Button Replacement
Post by juli »
Instructions for replacing E-Stop Button on a Denford Micro Machine
Install new E-Stop switch. You may have to trim off the small alignment dimple. Carefully use a small sharp knife blade ( X-acto ) or a file.
Cut old terminals off wire and strip insulation back about ¼”. Crimp on the new terminals.
Install wires on the two terminals of the switch marked with the black line ( #11 & #12 ). Carefully push on; these have a very tight fit.
For 4 wire E-Stop switches, use terminals 21 & 22 for the second pair of wires. Pair same color wires together. ( I.E. red to red-11 & 12, blue to blue-21 & 22 )
Martin, Steve, Mr Magoo
