Hi everyone!
Tried to start my Orac this morning after SD2 drive repaired and tested and noticed new problem...X-axis losing direction.
Personally I do not consider myself as capable locating the faulty part or whatever may have caused this.
Both drives work fine with Z-axis. Does the sequence the green/red led's switch on/off , flickering has to do anything with it?
Any ideas gents of how to proceed?
Thanks!
Do you mean it is changing direction or losing position ?X-axis losing direction
If you connect the X axis output to the Z drive then moving the X axis from control works the Z motor OK ?
Given the age of this stuff, you really need to be looking for hard / broken wires, loose connectors/screws, corroded pins etc...
I mean the X-axis moves at random direction. The Z-axis works fine. Plugging-in the X-drive to the Z-axis again the Z runs fine responding to commands. It is not the drive now that causes the direction problem. I noticed for an instant the shaft starts rotating CW but before it completes a full 360 deg revolution, something like 1/4 of a turn reverses and runs the wrong direction. for as long i hold the arrow button pressed.
I think, I've read in the drive manual that it needs a 0Volt signal to be applied to pin 5 of the drive in order to reverse.
So, i need to check if this zero volt signal is present whenever i press the arrow button for reverse.
Thanks for the response
It sounds more like you have a broken stepper motor wire. The motor connections are in the box behind the light so it may be worth checking inside.
