My spindle will not run now though. I downloaded the Micromill schematic but am not good enough electronically to figure out what the system is looking for that it's not getting now that I've removed the top board.
All the fuses check OK, at least the 4 I found. Both of the 2 relays pull in when the system is powered up, the spindle on/off rocker switch lights up when clicked on and the light goes on & off when the plexi front door is raised & shut.
My spindle controller is the KB KBLC-240DS. I checked the L1 & L2 inputs and it's only 17 volts with the wires unplugged. I think it should be mains voltage (110v here in the U.S.)
I'm guessing there's a signal missing somewhere. Anybody have any suggestions? If not, can I just unplug the existing power leads on the controller at L1 & L2 and just plug in 110v power to check and make sure it does run?
Thanks for your thoughts.
