VR CIM and VR ROBOT
VR CIM and VR ROBOT
Post by Steve » Tue 01 May , 2012 1:58 am
Can anyone tell me if these packages will work with Windows 7?
If not what is the last version of windows that could be used?
Thanks.
Re: VR CIM and VR ROBOT
Post by bradders » Tue 01 May , 2012 13:56 pm
Loaded VR CIM and VR Robot on to a Windows 7 Home PC. It seems to install OK but when you try to open rooms you get an Access Viloation Error in VL-Link.exe. I suspect this is the VISCAPE graphic driver that is causing the problem. Admin may be able to give a more exact report.
Post by Denford Admin » Fri 04 May , 2012 14:11 pm
It should work with XP mode on windows 7 but I haven't the resources to try it here.
https://www.microsoft.com/windows/virtua ... fault.aspx
