VR CIM and VR ROBOT
Can anyone tell me if these packages will work with Windows 7?
If not what is the last version of windows that could be used?
Thanks.
Re: VR CIM and VR ROBOT
Loaded VR CIM and VR Robot on to a Windows 7 Home PC. It seems to install OK but when you try to open rooms you get an Access Viloation Error in VL-Link.exe. I suspect this is the VISCAPE graphic driver that is causing the problem. Admin may be able to give a more exact report.
It should work with XP mode on windows 7 but I haven't the resources to try it here.
https://www.microsoft.com/windows/virtua ... fault.aspx
