Help with starturn
Help with starturn
Post by 1081275 » Tue 04 Jan , 2011 22:44 pm
I've two lathes, i remember that we had a Dos Software for this lathes but the computers are broken and with the development of new softwares i wanna know if you can help me, because i would like to put them working properly, i have a lot of dought, can use mastercam or any other software to run this lathes? I normaly use mastercam that's why i'm refering to it. I have used the dos software once but i didn't like and as we are a school for teaching we need a better and newer interface. Please help me if you cam, otherwise we will have to buy new lathes and it's a shame because they are like new and i like this lathes.
Model: Starturn
Serial: EO 4000/14
Year: December 1991
Serial Number of Electr.: 53270
Thanks a lot.
Re: Help with starturn
Post by Denford Admin » Wed 05 Jan , 2011 17:41 pm
Unless it has a Baldor/Optimised control (which I very much doubt being 1991) then you will have to have it retrofitted with modern software like Mach3
Here are my standard Starturn links for you to look through:
DOS machine software PLUS Photos and Drawings:
viewtopic.php?t=196
Dos Software free downloads:
https://www.denford.ltd.uk/index.php?opt ... &Itemid=51
Starturn problems:
viewtopic.php?t=1113
Dosbox:
viewtopic.php?t=844
Fanuc OT offline turning Programming manual DOS version PDF:
viewtopic.php?f=15&t=2324
DOS Turning Software Manual:
viewtopic.php?f=15&t=953
1081275
Post by 1081275 » Tue 11 Jan , 2011 10:52 am
Yes i'll need to retrofit the lathe. Can send me information about the restrofit of starturn lathe.
Thank's a lot :).
Post by Denford Admin » Tue 11 Jan , 2011 12:02 pm
davidimurray has retrofitted at least one Starturn...
viewtopic.php?f=46&t=452&start=20
Plenty of others on this forum have also retrofitted old Denford machines with Mach - it's just a case of reading through the posts
