FANUC CNC milling(soft homing issue)
Help and info about Denfords CIM* and Virtual Reality CIM systems Robots and ASRS**
*(Computer Integrated Manufacturing) **(Automated Storage and Retrieval System)
umair
Post by umair » Mon 08 Apr , 2013 14:24 pm
Hi, we are working on a denford CNC milling machine and the problem is we are not able to soft home the machine in the desired co-ordinates... Need help regarding that. Thanks
Re: FANUC CNC milling(soft homing issue)
Post by Denford Admin » Mon 08 Apr , 2013 15:52 pm
Which machine and software have you ?
Is the machine physically moving to the home switches and backing off slightly ?
Both vrmilling v2 and v5 have help files showing how to set the work offsets so that the machine datum is in the correct place.
Post by Martin » Tue 09 Apr , 2013 8:12 am
If it's a true Fanuc control then power up with "P" & "Can" pressed.
