Triac and Mirac PC
Triac and Mirac PC
I have a Triac PC SR#EO4012 (April 1992) and a Mirac PC SR#EO4448 (May 1994). The Triac ran for a few years and the computer that it was hooked to died.
Long story short the IT department here at the school "misplaced" the installation software and the floppy disk that I'm told acts as the dongle. I've downloaded the software, but I'm having trouble finding what I need to get around the dongle issues.
The Mirac to the best of my knowledge has never been operated here. Can someone point me to what software I need to get it started?
KR,
Cody
KR,
Cody
- bradders
The Triac PC SR#EO4012 (April 1992). had DOS software ver 1.05c and a Eurostep Issue 3 contol board and this would upgrade to VR Milling Ver 5
Mirac PC SR#EO4448 (May 1994). had DOS software ver 2.19 and a LCB3 contol board and this will not upgrade to Denford's latest VR Turning software.
FYI the old DOS software is free to download from our web site (See link below) and comes as is, we can no longer offer support for these products
I will forward a link to Denford USA
Denford INC in the US should be able to sort out a replacement license floppy disk for you to get them back working as they were.
Their email address can be found here:
https://www.denford.ltd.uk/index.php?opt ... &Itemid=31
Denford no longer support the DOS software.
The final versions were unprotected so do not require a licence key and are available for free as a download.
While it may be possible to produce a licence file this would be time consuming and very expensive.
You should use the downloads available from the website.
I assume you mean the windmill.ini file(as noted here: viewtopic.php?t=100 ) ? If so, there is not a windmill.ini file in the vrmilling folder.Martin wrote:The Flash Codes needs to be in the ".ini" file.
I'm not sure if it was version2.** now?
The user manual has a part number: 700312 - not sure if this will help identify a software version it's tied to. The first page of the manual in the "legal" portion pertaining to trademark etc, calls out Copyright Denford Inc. - Version 4.0 June 2002
Again not sure if this tied to just the manual or gives a reference to the software it was running also.
Thanks for the help thus far!
Have a look at this:
viewtopic.php?t=173
If you have DOS, then use FANUCMD (for Triac) and the machine connection should act as the dongle, so no need for the flash codes (unless you want to run offline)
Also look at this post if it is VRMilling v2 that you have:
viewtopic.php?t=100&highlight=windmill
ps - a picture of your machine and the inside of the electrical comartment would help us know exactly what we're all talking about
viewtopic.php?t=173
Here are some pics of the machine and control cabinet.
- Denford 001.jpg (92.93 KiB) Viewed 19823 times
- Denford 002.jpg (196.89 KiB) Viewed 19823 times
- Denford 003.jpg (149.58 KiB) Viewed 19823 times
- Denford 004.jpg (181.3 KiB) Viewed 19823 times
- Denford 005.jpg (159.5 KiB) Viewed 19823 times
- Denford 006.jpg (132.4 KiB) Viewed 19823 times
Re: Triac and Mirac PC
I was finally able to get the issue resolved through Denford US. They were able to find the school information and issue us the original flash code to enable VR milling. I appreciate the help from everyone and apologize for not responding sooner.
