Dongle not found (VR Milling Ver 2.**)
After i install VR Milling Ver2.** i get the message "Dongle not found" when trying to run the software
Initially the VR Milling Ver 2 software only ran if a Dongle with the correct attributes (MILLER32) was located in the parallel port of the PC. If the dongle was not present then the message "Dongle not found" would be displayed.
Later developments in the protection of the software allowed FLASH CODES, these codes were on a 3-1/2" floppy titled "Registration Disc" and the appropriate box ticked for VR Milling.
The sequence that the software used, was to look for a Dongle first, if it did not find one, it would then look for a flash code and if it did not find a flash code it would display the "Dongle not found" error message. It really should have been "Dongle/Flash code not found".
Therefore you only need to put the "Registration Disc" in the drive, navigate to the contents of A Drive and double click the FLASH.EXE file and it will install the Flash code
Alternatively (or if the FLASH.EXE doesn't work)...
  • go to the location of the file flash.ini
    double click this file (it should open up in Notepad)
    press CTRL-A to SELECT all the text
    press CTRL-C to COPY the text
    close notepad
    go to c:\program files\denford\vrmilling
    double click on windmill.ini (to open in notepad again)
    :!: double check there are not already entries for FLASH_USER or FLASH_CODE :!: - if there are, then delete them
    then at the top of the file, press enter to create a blank line
    press CTRL-V to Paste the text in
your ini file should now look like this....
Code: Select all
[FLASH]
Ini_File=Windmill.ini
Flash_User=some school, someplace, UK
Flash_Code=R44N-HC8X-AT4T-3FGN-G9DR-62U8
[directories]
machine list file=C:\Program Files\Denford\VRMilling\machine list.ini
XNC Folder=C:\Denford\Data\
Mr Magoo, Martin, Steve
