Would an Orac 100mm chuck fit a new Novaturn?
dg
Post by dg » Fri 23 Feb , 2007 22:34 pm
Hello all, would an Orac 100mm chuck fit a new Novaturn lathe?
Many thanks,
David.
shakey j
Post by shakey j » Sat 24 Feb , 2007 17:06 pm
Anybody?
Triac whizz
Post by Triac whizz » Sat 24 Feb , 2007 19:39 pm
Suck it & see :lol:
if not I'll give you something for the chuck :)
www.la-coterie.com
Post by Denford Admin » Mon 26 Feb , 2007 14:27 pm
Without trying to guess whats on the Orac I'd agree with Triac Whizz:
Suck it & see
You could hopefully make your own adaptor plate if needs be.
Post by Steve » Mon 26 Feb , 2007 18:20 pm
I am sure you can get an adaptor plate to make the chuck fit.
Do you have an automatic toolchanger?
If so you will have problems if you have any internal tools fitted in the turret disc as they will colide with the chuck jaws!
If you take out the internal tools there is no reason why you cannot use the chuck.
You should have enough clearance over the cross slide.
shakey j
Post by shakey j » Tue 27 Feb , 2007 23:27 pm
Well dg what do you think? :wink:
dg
Post by dg » Wed 28 Feb , 2007 10:51 am
I shall give it a go and see!
I do have a tool changer
Thanks for everyone's replies
