Spindle will not re-start after toolchange
rasp
Post by rasp » Sun 08 Jul , 2018 15:56 pm
Hi All,
I have owned a Mirac for many years and it has been working fine until now.
My machine is the LCB3 type with the single inverter for spindle and toolchanger. After a tool change the spindle will not re-start, then after what seems like 2 minutes it starts running, the problem seems random as it can run for a few parts or it can do it on the next tool, my concern is, depending on how long the delay is before the spindle re-starts the tool sets off into the stationary work after a short delay as if its in a wait loop that has timed out. Any ideas what to look for would be a big help.
Graham
Re: Spindle will not re-start after toolchange
Post by Martin » Sun 08 Jul , 2018 22:00 pm
Check that the toolpost is fully back. You should not be able to feel any movement in the toolpost faceplate if it's locked back. It may just need lubericating.
rasp
Post by rasp » Sun 15 Jul , 2018 9:24 am
Thanks for the reply.
I checked that and it seems fine, I also put more oil in the little ball valve lube point but that made no difference.
I can hear a small relay click in the back but not the big one that normally sounds.
Any more ideas anybody?
Graham
Post by Martin » Sun 15 Jul , 2018 10:45 am
It may be worth trying some manual toolchanges to check the toolpost cycle is complete, It should update the tool position on the screen when complete.
It may be as simple as having to bend the toolpost clamp switch slightly to activate it earlier. You can get to this by removing the aluminium cover plate on the toolpost.
rasp
Post by rasp » Sun 22 Jul , 2018 1:01 am
Well I give in, its been working just fine since I posted on here so I have no idea what is going on.
Thanks for the ideas but right now I am not going to fix what ain't broke
Graham
