Micromill Problem
kestech
Micromill Problem
Post by kestech » Thu 23 Jul , 2009 16:00 pm
I have a AES TechCenter 21 Micromill that was purchased as a Demo unit with a 1 year warranty before the US office closed. I have talked to Steve about it because the Y axis was not moving. I have since got it to move since loosening the jib, as Steve suggested. My problem now is when I try to home y, instead of moving towards the home, limit switch it moves away until it can't move anymore. What can I do here to correct this?
Thank you! :doh:
Re: Micromill Problem
Post by Steve » Thu 23 Jul , 2009 16:37 pm
Having just spoken to you I can confirm that the Y home switch apears to be the problem.
The machine should drive towards the microswitch at a high speed then when the switch is hit (breaking the contact) it slows down then reverses at a slow feed. Once off the switch the contact recloses and the axis is at home.
I understand you have a spare switch so let me know how you get on.
Useful Links
viewtopic.php?f=4&t=1973&hilit=home+micromill
viewtopic.php?f=2&t=1183&p=3991&hilit=h ... mill#p3991
Post by Steve » Fri 24 Jul , 2009 8:31 am
The problem still existed after changing the y home switch.
On further investigation the problem was found to be a loose wire on the home switch where they enter into the Nextmove card.
