Hello
After a few years light use our school vertical router has suddenly started making a worrying noise. Jogging on the z axis there is an almighty squeeking.
Perhaps there is some oiling required but it is beyond my knowledge. I have never seen any documentation about maintenance.
I have some course work waiting to be cut but await your response.
Phil
Squeeking on the z axis
- Hardware/Software: QuickCam 2D
QuickCam Pro
VR Milling 5
Denford Vertical Router
Re: Squeeking on the z axis
Upon further investigation I see the accordion gaiter below has come lose. It appears some dust has gotten into the z-axis thread which is causing the problem.
My proposed course of action:
1) Blow out as much dust as possible with air.
2) Lubricate
3) clip back into position the gaiter
Does that sound like a reasonable approach? Do I need to lubricate and if so with what?
Phil
2) Lubricate
Phil
Hi Phil
Take a look at page 30 of the user manual as attached.
- Vertical Router Operator Manual.pdf
- (684.59 KiB) Downloaded 935 times
QuickCam Pro
VR Milling 5
Hello Martin
Thanks very much for that.
Phil
Phil
QuickCam Pro
VR Milling 5
We are back up running after some overdue maintenance. Now I see we have a broken part that needs replacing.
The most forward metal plate clip that holds the accordion gaiter has bent. The actual accordion seems intact but ruffled.
Can I purchase a replacement plate or gaiter (whichever is easiest) from Denford? I cannot see it on the web site.
