Starmill Setup
I would like some basic knowlegde about setting up the machine:
How do you set the tool datum on the block you are machining?
Is the the spindle activation only done through the G code file?
What sort of Speeds and feeds will I achieve?
This will get me started.
I can't find a manual that old.
Have you run the software MrMagoo pointed you to ? It looks like there may be some basic help in the Starmill SMCU software
Other than that, I guess you need help from someone else who is still using this system
