We have finally got round to having a go at making our F1 car. Please could i have some help to set up the for machining of my designed car. The RHS program works a treat ,then when change to the LHS its producing an offset cut.
I have measured the step..1.375,halved it and added to the Y axis but it doesn't cut equally .I have re set the datum points on the Denford 2600 many a time, but to no avail.
Currently Using : Fusion 360,QCPRO,VR6 Milling
Hi DTTechboy,
Please see this forum post which has downloads and instructions on how to fine tune your offsets when machining a STEM Racing car.
https://www.denfordata.com/bb/viewtopic ... tup#p26070
if the offset changes over the length of the car, then this indicates that the fixture is not aligned correctly with the axis.
Mitch
Mitch
