Hardware/Software: Viceroy VS280
Drg ML100 523
Post by Paul Page »
Does anybody have the drawing ML100-523 or know what the part spec is please. It's called up on assembly Drg. ML100-500. It could be a ball bearing
Hardware/Software: TDS 1/2pcs metric lathe. sharpedge TDS12/16
Re: Drg ML100 523
Post by Nand »
The drawing is available in the "ML drawings for 5" TDS lathes" info file above. In page 1, first section, beneath "ML110 scan ndex text" there are links to two files. The "drawing file" contains the drawing for the part around page 54. (feednut locking slug - there are two versions).
Re: Drg ML100 523
Post by Paul Page »
Sorry Nand, I can't see the drawing file...above. it would be great if I could access it. How do I find it. Paul
Re: Drg ML100 523
Post by Paul Page »
Oops. Found it. Thanks for your help.
Martin, Steve, Mr Magoo
