Mirac X position changes
Posted: Mon 22 Feb , 2021 12:57 pm
by davejfowler
I have a mirac lathe with an 8 position changer. Everything seems to work as it should. The only issue I have is that the Xposition changes over the course of a job. Usually on the plus material side so I have been working around it. Cutting from 50mm dia down to 8mm in 0.5mm cuts on brass the X will shift up to around 0.4mm its a little annoying but I have no idea what is causing this. I dont think the tool is slipping in the holder. Could the lead screw be slipping from the motor position? Any thought would be helpful! :)
Re: Mirac X position changes
Posted: Mon 22 Feb , 2021 20:42 pm
Have you lubricated the X axis recently?
Posted: Mon 22 Feb , 2021 21:51 pm
by davejfowler
Hello Martin, thanks for your note! I haven't done anything manually, though there is an oil feed which I assumed was lubricating the axis? Does this need to be done separately?
Posted: Tue 23 Feb , 2021 9:29 am
It may be worth running the lubrication until you see the oil coming out of the bottom of the X axis slide.
Just create a program that runs the spindle at 800rpm & move the X axis up & down with a M99 at the end to repeat.
The oil pump is activated when the spindle is running.
Posted: Tue 23 Feb , 2021 15:46 pm
by davejfowler
Thank you again. I've now run it over and over and I can see the slide is glistening with fresh oil. Still seems to happen. I can home between final cuts but I didnt think the axis could lose position like that. Is there possibly a coupling slipping?
Posted: Wed 24 Feb , 2021 15:52 pm
by davejfowler
Martin wrote: Tue 23 Feb , 2021 9:29 am It may be worth running the lubrication until you see the oil coming out of the bottom of the X axis slide.
Just another thought, are there bearings that position the screw axially? could they move in a housing or be worn?
Posted: Wed 24 Feb , 2021 21:14 pm
There is a Tab nut that tightens on to the bearings but because its on a slant it should drop down. It may be that the jib strip needs tightening to allow for wear.
Have you tried running with the feed rate turned down to 80%
Posted: Fri 26 Feb , 2021 11:21 am
by davejfowler
Great i will try to find that, and check the strips. I haven't adjusted them as the slide feels rigid, but maybe that's due to the weight.
Thanks Martin!
