USB to RS232 adapter
abj
Hardware/Software: microrouter pro
Post by abj » Wed 02 Jan , 2019 12:05 pm
Does anyone know what are the requirements for a USB adapter. I'm told some will work and some not, the one I have just got will not. i want to upgrade to VR milling V5 and have a replacement RS232 cable, configured as per Denford machine specific instructions.
MadeForThat
Nextstep-4 axis
Novaturn ns:
denstep card (from swap)-atc
Re: USB to RS232 adapter
Post by MadeForThat » Thu 03 Oct , 2019 15:14 pm
well I don't know if you are still checking this, or if you ever got an answer, but this adapter has been working for me with windows 10 and vr milling 5 as well as Vr Turning:
https://www.amazon.com/gp/product/B01DY ... UTF8&psc=1
if that link doesnt work in the future, it was called the "tera grand premium" usb to rs232
I have also been using one of these to switch between my 2 machines:
https://www.amazon.com/gp/product/B000I ... UTF8&psc=1
That is a 2 way db9 switch box, and allows me to hook the usb to db9 cable to it, and then connect my 2 machines to that box. Really nice to not bother with switching the db9 cable. Come to think of it- now that I have a usb adapter I don't need to switch between, I could just use 2 adapters :doh:
Post by Martin » Fri 04 Oct , 2019 10:07 am
We had several issues connecting using USB to RS232 adapters running on windows 10.
We found that a UGREEN 20210 USB Serial Cable, USB to RS232 DB9 9 pin Converter worked correctly.
https://www.amazon.co.uk/UGREEN-20210-C ... 157&sr=8-2
