Hardware/Software: Orac / Mach4 / UCCNC
I was just wondering if anyone knows what diameter the spindle pulley bore is and the keyway size is?
Looking to put a taper lock HTD pulley on it with a servo motor to upgrade an indexing spindle.
Thanks,
Rob
Rob
Einstein ― “If you can't explain it to a six year old, you don't understand it yourself”
...working my way through the 1000+ ways things don't work to find the one that does
Spindle pulley is 30mm dia, keyway is ~8mm wide and ~3mm deep (into the pulley)
Spindle pulley is ~61.7mm dia
Motor pulley is ~ 34.7mm dia
Pulley ratio is therefore ~ 1.778:1
Rob
Martin, Steve, Mr Magoo
