vr milling v2 with nextmove controller
donm0098
Post by donm0098 » Tue 12 Sep , 2017 17:38 pm
I have a triac PC that has been upgraded to work with USB.
Does VR milling version 2 work with the triac USB upgrade? I can communicate with the controller card via the USB and the serial port OK using mint workbench and denford easy upgrade software. They identify the card as a nextmove st. But VR milling version 2 does not find the mint controller.
Will I need to get VR milling version 5? Or can I reflash the controller to work with VR milling version 2?
Re: vr milling v2 with nextmove controller
Post by Martin » Fri 15 Sep , 2017 23:13 pm
VRMilling version 2 should work a NextStep card/ You will need to select an NS machine type.
donm0098
Post by donm0098 » Sun 17 Sep , 2017 1:58 am
Thanks for your help Martin. Changing the machine to TriacNS fixed the communication problem.
