Problems with sharpedge.
SJN
Post by SJN » Thu 17 Aug , 2017 20:47 pm
Can anyone tell us why the machine is not drawing oil up the pipes to feed the stone, it is almost as though air is blowing down the pipes.
DavidB
Re: Problems with sharpedge.
Post by DavidB » Fri 18 Aug , 2017 12:12 pm
The Sharpedge I've dealt with had what looked to be a petrol pump operated by a cam on the motor shaft so if your not getting any oil pumped then that would suggest that the pump has failed in some way, possibly a failed diaphragm, not an usual failure for such a device.
