machine stops at every G code
microrouter v4ns
running vr milling ver.2
every time the machine reaches a line that begins with "G" the machine stops. as a workaround, someone babysits the machine, hits pause and then play for the machine to move on. it works, but is annoying. i feel like i just have a setting wrong. any suggestions?
Re: machine stops at every G code
What version of VRMilling 2 are you running?
the problem disappeared the last time the machine was restarted! wierd, since we had tried a power cycle...i wish all problems were this easy to solve.
