So after a bit of faffing about I have my Micromill hooked up through a breakout board and axis moving.
But LinuxCNC is asking for some settings I dont know.
From searching on here I gather that the basic resolution is 8000 steps per inch, but would be good to know the native steps per revolution and driver microstepping (and lead screw pitch but I will try measuring this)
Anyone know these?
George
Linux CNC settings
davejfowler
- Hardware/Software: Denford Micromill 2000
VR 2.8
Re: Linux CNC settings
Hello, did you get any answers to this, and have you managed to get this working?
I am in the process of replacing my control board, or breaking out and using third party software... Now sure how easy the latter option is, but would love to know how far you have got!!!
TDIPower
I am pretty sure you can find this out from looking at the machine set up info in VR milling. when you go to machine set up it asks for a password which is denny you should be able to see travel limits, spindle speed, steps per rev etc.
gsport
Solidworks
QuickCAM PRO
VR Milling V5
YES. Got all axis moving and spindle speed control working too. Using LinuxCNC and Pycamdavejfowler wrote:Hello, did you get any answers to this, and have you managed to get this working?
Also made a sort of adaptor for the spindle so I can get 128mm of Y axis
Seems to work well in terms of not missing any steps, but Pycam is not working great for me, might be I need to learn to use it more or might just be a bit basic.
I'm using 400 steps per revolution and microstepping at 1.0 (ie. none) seems OK but would still love to know if this is optimal.
George
