Viceroy TDS 1/1GBL Coolant pump drive belt
Does anyone know the size and dimensions of the vee belt that drives the coolant pump, i measured it and it seems to be 9mm at widest point and 10mm deep measured from outside of pulley to the bottom, any help on this please
Re: Viceroy TDS 1/1GBL Coolant pump drive belt
I've only managed to find an arrangement drawing showing a round (1/4" dia) belt, but I have a drawing of a motor pulley with a 3/8" wide groove for the pump.
So it looks like a standard 'Z' section belt.
I doubt it would be the slightly deeper 'SPZ' section as the power requirement is quite low.
Most on-line belt suppliers have a calculation tool to define the belt length based on your pulley sizes & spacing.
I thought all the TDS1 coolant pumps were made by Hoover ( of the carpet cleaner ) and used a Hoover drive belt. I ccan't remember if it was a Hoover Junior or Senior belt, and as AndyB says they were round belts.
I suspect your lathe has possibly been modified.
oldboyouttheback wrote:I thought all the TDS1 coolant pumps were made by Hoover ( of the carpet cleaner ) and used a Hoover drive belt. I ccan't remember if it was a Hoover Junior or Senior belt, and as AndyB says they were round belts.
I've checked the Denford modification notes - there was a change in 1972 to the motor pulley drawing (ML100/201) "To make 'U' groove in pulley to a 'V' groove. To suit new type of belt"
(There had been a previous change to increase the diameter of the 'U' groove in the motor pulley to make the pump run faster).
I can't find an arrangement or parts list yet that shows the new belt or a different pump though.
Thanks guys, Its not been modified as it came from a collage, and they said it was all standard,
